Clutch bell play ?
Rory
Hamilton near Glasgow
Just trying to fix my KM baja, and I notice with the clutch bell on and held in place via the bracket, theres still movement of the bell in and out of about 0.5cm. Is this normal ?
Any help appreciated
yea a bit of movement there is normal,
As long as the pinion and bell sit tightly together it should be fine with a little play, just make sure they are well and truely meshed together, otherwise you run the risk of snapping the bolt that holds them together.
Again like when you had a melted spur, check the clutch bearings on the carrier.
