clutch bolt holes?
If i'm not mistaken the zenoah clutch has 8mm bolts i just measured mine to see myself and they are 8mm.
If I want to use a 10mm bolt hole clutch do I just use different bolts?Thought I read somewhere you have to change the housing also to do this:confused:
Yes, Zenoah bolts have the smaller shoulder on them than the CY's do. No need to change any other pieces Just bolts, wave washers, & shim washers.
