clutch housing
BOOTS
don't know if this has been metioned before, but you do need to change the clutch housing if using a zenoah engine. i tryed bolting my zen in with zen clutch housing and just wouldn't line up as the crank case hit on the center diff
When I put a zen on my baja I had to use the clutch housing off my CY in order for it to fit. The zen has a nub that sticks out that got in the way. But the CY housing lined up and worked fine with the zen engine.
RampageHopUps said:
The fan cover should also be a problem. I had to slot my chassis holes just like the Baja.
+ 1
just changed the clutch case to be safe, no probs now
never had a problem with using zen case on my baja though.
