ipsagel1
Hi rampage guys!
I owned a Rampage Mt and had used it for not more than 20 hrs total run time since I opened it from the box. I noticed when I started running it that the clutch doesn't engage well, but just don't give much importance of it until I've done with the engine break-in.
This time I tried running it with full trottle and noticed that the truck was so clumsy and doesn't have enough torque to push the truck. I tried climbing it to 30 degrees hill but the truck could not climb and the wheels stop spinning. While reving the engine the clutch just slip the clutch bell. One day i broke the clutch spring while running the truck.
I ordered a high responce spring from DDM the red colored one I think it's 8000 rpm. after installing it and make a test run the more that the cluch won't engage well, it just barely move the truck in full trottle. So I get back ordering the original spring and ended up with the same problem as before.
My engine is the stock rampage 23 cc engine- do you think guys my engine cannot rev up to 6000 rpm or more to pruduce a centrifugal force that will stretch the spring so that the clutch will engage to the clutch bell? I already made adjustment with the carb a little leaner than the factory setting and I'm
afraid if I keep on leaning it my engine will be damage.
