Cntr Diff, Gear Plate, Tire/Whl
hamster huey
Wichita
Do the xt/b have a fluid center diff? Do they use the same gearplate and gears as the TT/MT/Dunereunner? Are the tires soft or hard rubber?
Its pretty much the same "center" driveline as the Rampage. There are a few changes but it is essentially the same. There is no center diff, its a spool just like the original Ramp. The gearplate and gears should be interchangable between the 2 models. I wasn't able to discern any huge between between them visually. The tire compound is fairly hard, its noticeably firmer than a stock HPI Dirtbuster. They should last a prtty good while if you do not abuse them on concrete.
Gears will be different than the Himoto steel gears,a nd not interchangeable between them. You can;t mix Himoto steel gears with Redcat steel gears.
No center diff? That sucks. I thought for sure they would have done that as an improvement.
