X2Boss
Got a problerm with my could again I belive, is shorting out (countinuity tester between Red live and Neautral black) straight from the coil, ordered and new on and it's doing the same ?
Also from live to engine head it shorts out and same black ... Again please note "Switch Blade" kill switch is disconnected at reciver and from kill switch at this point so no wire could be shorting else where.
This is causing engine to ground, got good spark and correct gap on fly wheel...
Please not this was with be switch disconnected which the switch works perfectly fine.
I'm starting to think it's something to do with my "Switch Blade" kill switch as this is the second coil now only on my fourth tank of petrol ?
Any ideas
Any ideas
