Coil Slipping
Phill2
The Rock QLD Aus
Hi Guys
I'm running a Zenoah G290 and after every run the coil is rubbing on the flywheel
I adjust it and after the next run it's rubbing again
The bolts are tight and I don't want to use Loctite in case it slips and I can't get the bolts out
Any ideas?
Thanks
Phill
Thanks but I don't want to use Loctite in case it slips and I can't get the bolts out.
I've had probs getting Loctited bolts out before even with heat
Found the problem
One bolt is broken leaving only about 3/8 inch of thread going into head
It's broken too far in to get hold of
Any suggestions?
drill it / ease out! , get a slightly shorter bolt , or trim one. it likely bottomed out and broke. if its bottomed out , something maybe missing...lock washer, flat washer[coil] plastic spacer. the spacers can be split look for that as well.
the red may hold for sometime
redbull pylon races on one screen, isle of man on the other with Ravel on the stereo while hi on redcat wrenchin'
phreerider said:
drill it / ease out! , get a slightly shorter bolt , or trim one. it likely bottomed out and broke. if its bottomed out , something maybe missing...lock washer, flat washer[coil] plastic spacer. the spacers can be split look for that as well. the red may hold for sometime
Trouble is bolt was loctited in with red
I have a spare cylinder I'll use when needed then look at maybe drilling out and retapping.
While its going I'll leave it alone
