alfred e numan
- Reaction score
- 0
Here is how to test the ignition coil on the engines we use. Disconnect the kill switch wire where it connects to the ignition coil. Connect 1 ohm meter lead to the disconnected terminal on the coil. Connect the other Ohm meter wire to the coils metal base - the meter should say .5 to 1 ohm. next- remove the probes wires, pull the spark plug cap, connect 1 probe wire to the coil wire, the 2nd probe wire to the coils metal base. The meter should show approx 6000 ohms resistance. These measurements will give you a rough idea of the electrical condition of the coils primary and secondary windings- and the condition of the plug wire and cap. There is a saying- its volts that jolts- its current that kills- so be careful around electricty.
