compression test?
andyken
New Hampshire
Is there way to check compression on these little motors?
Is there a good/bad range?
Can a psi compression tester like used on cars work?
I have used them before on 4 stroke motorcycles...
On another idea...
Has anyone heard of or used a "color tune"?
I used it on motorcycles, might work on 2 stroke..?
I don't know if you can use a psi compression test on our motors can't see why not but have no clue as to the psi operating range. I would assume that colour tuning is checking the colour of the spark plug. I would recommend to check plug colour anyway to make sure you don't run lean.
Color tune is a cool tool !
A motorcycle guy from the UK told me about them.
After warming the engine up, stop and remove the spark plug...
And install the color tune, it is a spark plug made of glass/pyrex.
You can look THRU the plug and SEE the combustion.
The color changes as you adjust the fuel mix, cool as hell !
You can run a compression tester on the engine as long as you have a receptacle or adapter that will fit into the plug hole. Most good compression testers come with various threaded attachments.
