couple of changes to my Chimera you will like
topblissgt
south Jersey USA
The off/on switch is in a inassessable spot and the nicad battery needs an easy way of charging. Here what I did to resolve those items..
Moved the switch to the side where you can get yo it easy. Also moved the connector to the battery outside the battery box (had to cut a notch in the top edge of the box to sneak out the wires)so now I can charge the battery in a second. I used two sided tape to hold on the switch.
That's my setup. Cut a bit (rectangular shape) from the side to let the charging wires/killer bee light remain outside.. voila.
No need to reposition the on/off button since the way you're placing it the switch will definitely fall off
There is a need to move the switch because it is a pain in the neck to get to but this will give your switch and plug protection from dirt sand and dust instead of just having wires hanging out all over the place.
I might do this to my xb.
What do i need exactly?
