The same thing happened to me. Did any of the welds actually crack? If not, you're in luck. I have worked through all those issues and can help with any mounting problems.Blackout said:Right, after a very short bash, both mounting points broke off the pipe, the actual fan cover mount snapped off and the aluminium plate broke. Not sure what I'm going to do now as I do not know anyone who can make me a replacement plate. I'll have to buy a new fan cover though if I do manage to get a replacement plate. ARGGHH.
Luckily no welds cracked. I already knew the fan cover part or the weld on the pipe would break around that particular area because I really had to struggle to get those two points to line up, there was no give what so ever so it was only a matter of time. Is there any full proof way of attaching the pipe back on?Mike4130 said:The same thing happened to me. Did any of the welds actually crack? If not, you're in luck. I have worked through all those issues and can help with any mounting problems.
