46u
- Macon, Georgia
I have a race the 26th and thought I better run my Baja to see if I need to do anything since I put the Lauterbacher 4 shoe clutch and the CPI pipe on. I did several other things but nothing that should need any adjusting. The only two pipes I have run so far till today was the stock can and the side Mielke. The CPI works so well low end I do believe if I set the clutch up where it would engage at a little higher RPM good chance I could do wheelies.
As is the front end comes up and sometimes completely off the ground. Not much but where the front wheels are off the ground just a little or very light on the front wheels. Here at the house do not have a really good spot to check all out top end but I give the CPI pipe great rating so far. I am running a totally stock CY 26 FOR NOW.
Would like to hear more about the CPI big bore as I am building 3 new engines. All so would like to hear from others running the standard CPI with bigger engines.
Will check back after the race to let all know how it works on the track.
