Custom Clutch system
ika
Hi,
Because of short life of stock clutch, I made custom 78mm clutch system.
See pics.
As you see clutch has cooler fins attached, which will cool clutch - I hope.
Just little work to do, and will test next weekend.
Yes, but it does not works, does not generate any air flow. Already installedView attachment 7737View attachment 7738
/monthly_2015_05/ImageUploadedByTapatalk1431206568.553386.jpg.cb803c50e73bbbccd0e247413e1b9b3d.jpg
/monthly_2015_05/ImageUploadedByTapatalk1431206582.000942.jpg.5625e9775f65fcb5f0de228b719fdf52.jpg
Oh, ok, I didn't know the MT has different clutch components compared to the DR.
Its same for DR as MT, but front part(gear side) of housing is opened, not totally closed.
So I thing it not make any noticeable difference installing vented housing.
I tested my clutch system and it work super.
It grabs much harder than stock clutch, because its 78mm against 54mm clutch.
Also it blows hot air very well.
I hope my clutch will last much longer than stock.
I used this 78mm clutch http://www.davesmotors.com/gp420-gp460-clutch-assembly.html
It cost more than stock, but I also got clutch linings from mcmaster and going to replace when Worn-outs. Already done on stock clutch and worked same as stock if not better.
