custom made exaust for the baja
Has anything else been done to it other than the exhaust? I took me a while to figure out what was wrong with it, thought it wasn't a baja for a while. But then I realised it hasn't got the roll cage on it.
Seems to go really well.
Gazza
hi i would like to here it but for some reason im only geting the pic and the vid like its on paus it happens some times and pissis me of have you got an other link for me
its a 29cc head kit,with a boostbottle (yes they work lol),with a red clutch spring,an reversed clutch shoes,an ddm air fillter
bottom end is standard,23cc
give this link a try mate,see if that works
http://img532.imageshack.us/my.php?image=v2004081322mm0.flv
some pics of the exhurst
this one is with the end cap off,an showing you the baffles inside
these next are of it mounted,with the cage an wing on (sorry its dirty )
thanks mucker that did the trick
looks and sounds good just a few bits of tuning and then you will be pulling wheelies
its easy if you got some one to knock one up for ye nice
it is pretty much matey,the pipe inside the cap in drilled full of holes,an the gas has to pass through that to get out the rear,but as ive said i can also pack around the internal,baffel to alter noise,an power
