BrawnFG
- Thread starter
- #21
The Mrs was away this weekend, so I took over the spare bedrrom and finaly made a start. Below are a few images of the progress so far. When i've finished I'll do a propper write up so others can have a go as well.
The main bars are exactly 500mm long (which is lucky, as that's exatly how long the alu I bought is!), i've made it larger than the standard cage to try and get a bit mre protection. Though the first photos show it fitting over the standard cage, this was just so that I could get the angles right.
I did all of the bends with a plumbers hand bending jig, took a bit of force, but seemed to work well and the alu wasn't stressed too badly. I'm Brazing it together with HTS2000 rods and a blowtorch.
The only issuee i've had so far are:
1. brazing the next joint without the heat soaking away into a joint i've already done and screwing it up (I may make some of the horizontals bolted joints if i can't sort this).
2. Tapping threads in alu is a b###h, as the tap keeps getting gunked up with alu. I've also broken 2 drills and had to fill in 2 threads with weld as they got messed up by the tap. If anything, I think that making decent threads in Alu will be the secret to making this project work.
All in all, i'm hapy with how it's going, especialy because all I have are hand tools! got no time to do any more until next weekend, which should give me some time to think of a solution to the brazing and tapping problems.
Note that my repair on the pipe didn't hold, so I'm probably not going to weld up the meft side until I know what i'm replacing it with, probably JetPro.
Fitting and bending of main bars
Design so far without horizontal brace and rear triangulation
