CustomCVP.com
Here you go, life time warranty, hardware will be included, we are replacing the pin they used on the carrier with a SS 4 mm bolt, my pin after one week was all rusted and pitted, so add greeseing that to the maintaince list if you don't run the protectors. We sandwich a pivot ball between washers and use a longer sway bar mount screw. This makes the protector parallel with the drive shafts and not all cockeyed. Got a couple vids on the tube I'll get them over here. These are going to cost $30 plus $8 S&H to the USA, Canada, UK and all other countries the S&H is 20 dollars.
