mooman007uk
You don't want to run it with any needles all the way in, it will lean seize, it should be tuned to run rich if anything.....any bogging is a sign of a lean mixture
I think you may have misunderstood me, the idle adjusting screw is the one on the side with a phillips head, tapered tip and spring that adjusts the position of the butterfly in the card at idle not the L mixture screw which i said was 1 1/4 turns out.
if you run your h or l needle too lean by 1/4 turn or more the engine will bog due to lack of fuel, you'll have a high idle but as soon as you nail the th it'll starve for fuel ....on the h mixture it'll start to starve at the high end of the rev range like it's running out of gas. lean bog can be due to both needle settings that are way off or an air leak, not just an air leak.
i agree that on the top end if it's lean but not way off the motor will still rev hard, then get hot and seize if you keep running it.
2 types of bog down that sound slightly different...lean sounds like "war" when you say it and rich cackles a bit more
