CY 29CC no start
New engine - torn it apart again, replacing the cylinder gasket, replaced piston ring, nothing happens. Even put gas in cylinder, nothing.
Thinking the zenoah 31.8. I have that in my rovan and its badass now.
I can't believe that still won't run after all them parts, it will be something simple.
Most nee rc engines any more are 4 bolt. Actually haven't seen a 2 bolt for sale in a while.
My dbxl is 2 bolt I think. I forget now but thjnk the stock 23cc is.
Are they worth it? A plain Zenoah 31.8 vs a ESP Modified 31.8?
I think so. I put the kit on a zen 29 of mine and it rips. I think its a 30.5 now. But if im being honest my cy29cc in my mtxl spanks it. Dunno if its gearing, or better traction with bigger tires, but its significantly faster.
It's only a 30.5 is you fitted the +2 stroker crank ??
No, the coil works. There is a nice arc, and while turning it over and touching the spark plug, I got kind of a good shock.
I'm just going to replace it. But there are so many options, Im in the deciding stage.
You put the key back in the fly wheel ,an does the fly wheel still have a good strong magnet?
