hamster huey
Last weekend I broke a dogbone pin, servo saver got loose, and servo horn got loose- regular things that happen over time, no big deal. One time my engine acted up it was a worn throttle shaft. It drove me nuts until I could figure it out. Today all I got is ????? I put the engine together myself. I checked the H and L before and after it died. I use the blue headgaskets cuz they don't blow out. It has a 668 carb on it with fresh gaskets. The carb setting were at the base starting points which is a little rich. Tank is vented. Throttle servo horn is new. Coil to flywheel gap is good. The air filter is clean with only 2 tanks on it. What happened: Ran great for 3/4 tank, then idle rpm came up slightly, died once, started back up drove it hard, died again, wont start, when I pull the cord it sounds like the chamber has cotton in it. So now Im gonna take the head off and look. I just put new gaskets on over winter and added a ZRC and Shreadstack. Im going to check my holes through the carb,stacks, and head but I triple checked them before I put it together. Ill probably tear it apart to see and try a different carb. Or try a different spare engine. And I rolled it over and broke the body. Drywall tape, scrap lexan, and shoe goo here I come! I love my hobby!
