I would like to get a good run on this new motor some time. Should have took it easy i guess hehe...........http://www.youtube.com/watch?v=aT6etedOZsw
these are phatslackers 4.8's.. there is an issue with the 6mm's and volume capacity in the shock body. if its filled up too much it will hydro-lock. the piggybacks will fix that. the other little issue it the front shaft bottoming out on the shock cap before the chassis bottoms out. i fixed that by dremeling out the shock cap,piston nut, and cutting the excesse threads of the shock shaft.forist said:Could someone link me the 4.8 set plz
