DBXL DBXL Chassis setup = numbers?
smokinwheel
LSF Plus Member
PLUS member
Connecticut
Can anyone help me with some setup numbers for DBXL?
If I am not mistaken, they call for caster to be somewhere between 1 and 3 degrees. I assume this is front and rear. Anyone have any input on toe and camber?
Done some snooping around and can't seem to find what I am looking for.
Hoping someone here with experience might have some input. Thanks in advance for any help.
It only shows camber at -1/2 to -3 degrees.
No caster ; not sure I can set that. But want to see what it is.
No toe numbers. It shows link length but no actual numbers.
I was really wondering about actual degree readings and not link lengths.
Are you planning on racing it?
I might throw my hat into the ring.
For now I just want to get it better. It never seemed right since it came out of the box. I have not actually checked to see exactly what it was/is currently.
Now that I have some setup plates, I can get some more accurate measurements and settings. Off season here so trying to get anything done I can before spring time.
Thanks for the link.
