DBXL dbxl pinion options ?
8000ft
New Member
I just picked up a a used DBXL and am wondering if there are any pinion options.
I live at 9000ft elevation and the 20 tooth stocker is a bit to high, I would like to try an 18T but I can not find any options out there.
i just assumed that 20 was stock because that is what was on it when i purchased it. i will check out dgi , thanks
no luck at dgi.............
just had a look around myself mate,
dgi are all larger than 20t, same with atop gears which are essentially dgi anyways,
and 30 degree north seem to start at 20t as well,
can only see 22t and 23t vertigo pinions listed for the dbxl, but you'd need the vertigo hex bell as @Seandonato73 said above,
there must be something out there that smaller than the 20t though,
