Munty Scruntfundle
- Reaction score
- 0
Hi folks.
I have a DBXL-E, it's completely standard electrics at the moment, with 2x Gens 4s ace 5760s I get around 6 minutes of general bash running which includes hardly any full throttle. It also cuts dead now and then, but runs well again (fish) after restarting.
I believe the standard esc is a rebadged hobbywing? without the ability to turn off the low voltage protection. Is this the problem here? Are these batteries not up to the task? Is the standard Fuse motor a bit pap?
I know there are diminishing returns for spending increasing cash on batteries, but without very expensive research I have no idea where the lines should be drawn. Is there much to be gained on splashing out on a couple of of 10,000mah units?
I have plans to upgrade but, if this is acceptable performance I may as well stay with what I have for now.
I also have a 5ive T on the bench which is being converted, I'll be putting the well proven Castle Mamba XLX and motor combo in that to start with, battery advice for that setup would be appreciated.
As a more general question, would you get more running time from pushing 8s flat out, or 12s at 75%
Many thanks.
Many thanks.
