DBXL 2.0 Dbxle 2.0 speed
Jbob
Thanks admins for letting m join. I have a dbxle 2.0 on the way. has anyone installed a max 4 esc and paired it with a castle creation 800kv and run 12s? I would like to get 80-85 mph for speed I’m not sure what gearing I will need to achieve the speeds I want to get.
Trial and error, you may go into thermal protection on your quest for speed. Generally speed runs on electric you get a run or 2 before you have to let everything cool down. Can't help much as I'm primarily gas but a buddy does run a dbxl- 2.0 with that setup and hit 70.. I believe he went up 2 teeth on the pinion to get 70
