DDM high flow fuel line kit
fastlane
Estherwood, La.
The kit is for a hpi baja but the way our ramps are set up they need that 90 degree bend coming out of the tank and of course the larger fuel line is a plus
better fuel line is the key. its nice to have the 90* angles coming out of the tank as well. the stock stuff get dry and crack, but it doesn't melt like some of the other stuff. the stock stuff coused and air leak for me that was hard to find. this is also a good kit. doesn't come with the elbows, but gives a nice one-way tank vent system.
http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.6470/.f
I have the FullForce fuel line kit installed in both my Rampage and my Baja. The brass tubes are a little small but I fixed the problem by inserting a piece of fuel line in the hole of the grommet then put the brass through the hole.
hey guy i have a sugestion y not get soft copper tubing and make your on elbow and u can make the tubing as long as you want. i haven't got to mess with my tt or mt yet still in iraq but thats wat im planing on doing .just a sugestion. wat u guys think?
