i use deans on a brushles sesc myself 200 amp continuos current 320 amp peak current and i have 0 issues whatsoever but my brushless is for 1/10 scale. the problem might have occurred due to batt being wired backwards
what esc, motor, and rc vehicle is this in?
a lot of people killed their MMM escs by running undersized batteries.
running connectors that can't handle the current will have the same effect as undersized batteries, voltage drop.
the 1/5th scale esc has 8ga cable, you really can't even fit 8ga cable properly on deans connectors.
i agree 8g is a bit big for deans, the reality is deans plugs were never designed for that sort of current (i seem to remember running them when 2400nicd were the hot ticket).
however, whats the alternative? a quick search and i found some bullet style plugs rated for $50 for one male/female set, rated for 300amps.
i use deans on 2s and 3s lipos LOL
your 1:0 scale truck only draws about 65amps though.
EC5s
you may wish to do some reading on the whole esc amperage thing. i read an article somewhere and in it stated that teh amp ratings of esc's was way off base to wht they could actually handle. for example take that esc in the pic. for it to handle the type of current you claim the internal ciruit pathways as well as the battery and motor wires would need to be WAY thicker than teh 8GA. wire that is on it this in itself would cause the esc to fail. i for one NEVER look at teh amp rating of an esc, i look at motor limit, battery capacity limit and thats it if it will work with the motor and battery i wish to use then it works for me.
personally i would neer put a brushless in a baja, to me baja means gasoline, if i want an electric i have (6) rc that are electric from 1/36 to 1/10 (unless you classify monster trucks like teh txt-1 and bullhead as 18 )
