More goodies came in this week.
These parts should help the Taylor 35cc engine breath better.
Thought about returning the Kraken spindle carriers due to the defect on the right side. Wanted to try something out with the set I have. I found a surplus of precision ball bearings that would almost fit. They are the flanged type with a 3/8 inch outer diameter and 1/4 inch inner diameter. Good fit for the M6 cap screw. I did confirm the dimensions of the parts including the offset of the flange and extended race would not be an issue before modified the parts. After drilling, I corrected the defect on the right spindle carrier.
If this is an epic fail, I will get new spindle carriers and use the bushings from the original parts. However, I may opt for some high load lubricated flanged bushings if the ball bearings fail. I also ordered some thrust bearings earlier so I can use those to keep the screw from backing out. Had done this to another 4WD vehicle that worked out quite well. Here is an image for reference. Thrust bearings on the upper and lower bolts. I have beat the crap out of this vehicle and the thrust bearings are still in good shape, the screws have not moved yet. It was an experiment that worked out.
To improve the handling characteristics of the front assembly, here are the parts. Still waiting on the upper control arms to be stocked.
Now for the best part, the transmission. The stock unit seems to have a flaw in the clutch bell design. Perhaps it is due to the welding process of the bell to the shaft. Damn thing wobbles too much. Defect by design or lack of process control?
The vertigo transmission seems to be a much better design. Double bearings for the clutch bell. Easy to change gears. Very nice assembly. Most important, no clutch bell wobble. It runs straight and true as it should. Got two sets of gears to start with. 20/21 and 19/22. The Vertigo trans setup complete with a single set of gears will run you $398.85 (excluding shipping and taxes) and the Kraken T90 list is $429. I see that Taylor RC has the 62mm clutch bell that will fit the Vertigo trans.
Since I have to do a tear down of the KV5TT, may as well experiment with some shock oil. The short springs I may experiment with as they should fit on the shock shaft. Doubt they are long enough for the rear shocks. I have longer one's at work with a higher spring rate than those in the picture. May not make use of them. At least the Taylor RC 35CC engine is not as heavy as the larger big bore engines. I guess Die springs would do the trick but doubt you would find any with a desired load rating.
Time to tear down the KV5TT and rebuild it. This should be fun.
