Deck spacer length.
From the front just behind the steering posts to the rear dif is about 400cm or about 16in.
It's a 10mm spacer. I have a spare set here if you want em. Actually, I have two pairs. PM me your address if you want em and I'll mail em out on Tuesday free of charge.
Thanks, Im a machinist. I just made some today.
If u are talking about the siver spacers i could really use a set.
You should make a spacer bar like the one Python sells and then bolt that to the chassis so you don't have to worry about those spacers getting lost. Either that or TIG weld the dam things to the chassis. Those spacers are a PITA to find at 2am after they've dropped off the workbench and rolled into the pile of powdered metal/dirt/leaves/spider webs/cockroach carcasses or whatever other horrors you may have under your workbench.
