Demolishers for my MT
mnbaja
Fort Ripley,MN
Well I got my first set of demolishers from rc4wd in the mail today.wow,these tires are huge! Now I'm saving for the other pair,and the ams adapters from ddm. Also so far for wheel choice fg chrome plastic. My only concern is these need glued,no bead locks ? Will the glue holdup on tires this large or should I invest in bead locks ? Thanks.
I prefer beadlocks, but the glue should hold up. The X Series vehicles run glued tires, and I've never seen one fall apart. I've seen some tires tear around the bead, but the glue held up.
Glue holds up fine. I like the beadlocks for ease of installation and disassembling.
MNRampage said:
I'm leaning towards fg glue wheels. Just because of the price point on the bead locks ?
They should work just fine for you. Post some pics when you have them all mounted up. :)
In the "Quick Reply" box down there VVVVV..
Click "Go Advanced" then click "Attachments" on the message box tool bar, it's the little paper clip. Then under "Upload File from your Computer" click "Browse" and select the image you want to upload. After you select it, click "Upload" and just close the window when it's done uploading. It won't show up in the message box, but it'll show up when you post the message.
MNRampage said:
Much larger ! I need to learn how to post pics ?
Sweet we need to see these!
If you are using a moble device, I find photobucket to be the easiest. The act is free. You upload into your account and just copy the img code onto the body of the forum. It will show as a pic once you submit the post.
Well change of plans for demolishers. After thinking it over the price of two sets of ams adapters $170,I decided to go with pit stop adapters and run Baja wheels. This opens up my options for later,and is less expensive.
So if someone is looking for a pair of demolishers with foams let me know !
I will post pics of the tires next to the stock mt tires.
MNRampage said:
Well change of plans for demolishers. After thinking it over the price of two sets of ams adapters $170,I decided to go with pit stop adapters and run Baja wheels. This opens up my options for later,and is less expensive. So if someone is looking for a pair of demolishers with foams let me know !
I'm sure someone will snatch them up. We're always reading "what's bigger" questions on here.
backinthepines
