claude bigelow
- Reaction score
- 1
That's what I was thinking, also need metal drill bits. The ones that came with the dremel aren't doing the trick.berto1230781 said:u might have to drill a hole in the middle of the screw and try again.
Combination of both worked thanks!!!! Now where can I get that washer I just cut in half? LOLrcgasser said:looks like you should be able to still cut a slot with the dremal and use a flat head to remove the screw another option would be to dremal cut the washer then that will leave a space and vise grip the screw and remove.
Ok thanks for the helprcgasser said:home depot sells them they are called finishing washers.
Working on it right nowrcgasser said:there is a gap in between the 2 bearing so you should be able to take a punch and put it between the 2 and tap them out.
