Demon RC - 2 Speed?!?
well if I sent you a motor mount/side plate from cen (fs) would you be willing to make one? it's an mcd basically but I believe the mounting holes are different on bottom, otherwise the same. just a matter of drilling and tapping the bottom. then you'd have another product line. I'll even do the pr on the fs forum ;)
I want this belt drive badly. I really hate the 4 gears. my f1 drivetrain is so smooth with the belt and quiet. that metal on metal gear set clanging drives me nuts
We would have to check that the layshaft gear is the same and that is spaced at the same distance. Also there is the length of the layshaft to consider. If I remember correctly the CEN gear plate is similar to the Evo2 plate.
If you could send me a layshaft and gearplate I can check it's measurements against our drawings and send them back to you. If you prefer, take a picture and put the hole dimensions on it. Do the same for the layshfat. It's the only way to really know.
I can send them down. pm me your address. I could just order you the parts and have them sent to you as well. stockparts are cheap... I want a belt drive LOL
