Diablo Build
pwaicon
South Lake Tahoe & Inland Empire, CA
There seems to be interest in the Diablo so I thought I would share my build thread over here also. It is always nice to see the inner working of the buggy. Well enough talking here are some pics.
Sorry guys, having a little issue uploading the pics, it appears I have reached my limit of uploads? I will look into this later and see if I can get some pics uploaded.
Took care of the problem, here are some pics of the rear diff. It only lets me upload 5 at a time.
Finishing up the diff and starting on the front suspension. The kit came with shielded bearings so I switched them with sealed bearings, some of the shielded ones I had to use because I didn't have the correct size in the sealed bearings. All the parts fit together nicely, very nice machine work.
I really like Nutech's new front C-Hub design, it is a huge improvement over the previous one.
Pipeous,
They are nice, you are going to like them.
Pics of the front bulkhead and the steering set up. Based of past experiences I decided to do a little mod and use larger diameter bolts on the Ackerman arm.
Time to finish posting up the build pictures. Installing the socks and clutch bell assembly. I used the HPI clutch bolt mod seeing how it shares the same design.
It comes with a nice alloy spur carrier and all the parts fit and finish is super nice. I had some FG cable brakes laying around and decided to see if I could mount them on the Diablo and they mounted quite easily with only a few little mods required.
