He is not talking IN the diff, he is talking outside the diff where the ring and pinion gears meet in the outer diff case. Silly putty there will not be goodRampageHopUps said:Never gonna work. You can try Silly Putty if you want to lock your gears and still be able to maintain them later.
To lubricate betterRampageHopUps said:Yeah, thats what I thought so in the begining, but why add fluid outside the diff?
+1 ... I use 'Green Grease' on my boat drive shaft and in my diff cases.rcgasser said:Grease will work just fine I use boat grease which has a high spin hold and when I do change the diffs there is always grease on the outside gears.
