Diff internals
Lopes3d
Build Thread Contributor
Reading
That time to pick some brains again, just been scouring the net and need the diff internals for a dbxl. Are the dbxl-e and dbxl the exact same fitment? Only part number I can find is LOS252067 which is marked up for a dbxl e and is a complete diff. But I’ll be going for a alloy case, so need the internals separate.
Just taken the centre diff out to rebuild, and blown a hole in the side and one of the shafts is sheared
I had the same issue I got dbxl 2.0 rebuild kit with new gears and used the aluminum diff housing from the e and used 20,000,000 wt diff oil works awesome solved all power transfer issues and zero tire balloning in front. Hope this helps.
