hi, here is a vid of the xtm grizzly/ carson/smartech firehammer, It has just had the jetpro v2 marder clone pipe fitted, power difference is huge and the top speed was alot better.
The car seems to rev alot higher and has added to the overall fun factor, the shell had to be cut on the back quater but that was well worth it.
I would say that it is easiest the best 'power' mod you could for the price.seems to be on par with my marder with jetpro pipe, 29cc engine, k n filter and 8k clutch which i clocked at 54mph.If you after a pipe for xtm/carson/firehammer, then i strongly suggest the clone pipe! it fit well, and not need to dremel the hole in the rear mounting plate (where it screws to the gear plate) like you need to do to jetpro. sounds great too!
