Differences between a 2013 5t and a 2016 5t
Dante
New Member
Hi guys
Wanted to buy a 5t and saw two models, a 2013 and a 2016. Both are used but the 2013 is a bit cheaper. Question is are there any differences between the two versions besides the electronics ?
Thanks
besides the motor? I mean diffs suspension etc. Or can I assume everything else is the same except for electronics and motor? Thanks.
Older version was definitely 2 bolt-26cc
New version shipped with a 29cc - 2 bolt or 4 bolt engine. There was no way to tell which one you got until you opened it up.
Mine had a 29cc 4-bolt....some others on this forum had a 29cc 2-bolt.
Mine had a 29 4 bolt as well and as far as I know you can't get any parts for it like gaskets internal parts ect for the motor .
Mine had a 29 4 bolt as well and as far as I know you can't get any parts for it like gaskets internal parts ect for the motor.
I haven't found any parts for it either. Luckily I haven't had the need to.
I upgraded the 5ive to a 320 and put the 29cc in the DBXL. It likes being in the DBXL way more than being in the 5ive.....doesn't have as much weight to push around.
