For those that have done the suggested upgrades to your differential i.e. bolts/nuts and pinion shaft bushings or even a simple diff service.
1. Do you typically replace the internal gasket, specifically the one on the inside of the ring gear or do you use them more than once? If you use new do you use them dry or apply a thin film of white grease or ? on them. I have new spares, just curious.
2. I have read of diff leaks. Is the consensus that this can be traced back to when the housing came loose and not an independent issue?
3. At this time I am going use the original 20K weight oil. To what height, meaning how far from the top of the diff housing are you filling the diff case so as to allow for thermal expansion and not create a pressure caused leak.
In my situation, all of my diff bolts were loose with several that had partially backed out and they all came out very easy. FWIW, this was an assembly rather than running issue because it’s only been idled and run moderately using less than 1/2 tank of fuel. And then when the two diffs were opened the gears spider gears within were coated with a film of oil but there no measurable oil within to drain out and no visible leaks so I have no point of reference.
Lastly, is there a consensus on whether the Nylocks are staying tight? Have any of you inspected your upgraded diffs after running your rig for awhile to inspect it?
I ask because within a thread posted not long ago the fellow shared that when he opened his diff, I think because of a diff cup failure that the Nylocks were no longer tight. He speculated that they were budget Nylocks. I purchased quality grade 12.9 bolts and Class 10 nuts so I am asking because I am debating as to whether I want to use Nylocks dry or conventional steel nuts with red Loctite.
Like all of us, after all the work I just want to assemble the diffs and not be concerned about them coming loose again because the secondary damage could be extreme.
My thought process has always been that the oil and heat may affect the Nylocks ability to retain a friction pressure value whereas the red Loctite once cured on a conventional nut will withstand both heat and oil.
Sharing your thoughts, opinions, and experience will be appreciated.
Thank you
Thank you
