Weights below. Each car is complete ready to run other than the Elcon Cleon. I used a different engine in there to just test weight so everything is there to the very last screw except the engine isn't bolted down because I am waiting for a different one. Each car includes battery, receiver and everything else a fully ready to run car would have.
FG Leopard Race #1:
21lbs 15.3oz (9kg 960g)
Full leopard race with added front disk brakes, 1 steering + 2 throttle/brake servos, carbon fiber servo tray, outerwears covers, sway bars on rear and pivot ball on front, ported 23cc Zen motor and alloy motor mounts.
FG Leopard Race #2:
20lbs 12.7oz (9kg 430g)
Full leopard race with can exhaust, front disk brakes, 1 steering + 1 throttle/brake servo, outerwears covers, sway bar on rear, stock 26cc Zen motor and alloy motor mounts.
FG Baja 2wd:
23lbs 5.6oz (10kg 590g)
Full FG Baja 2wd with ddm dominator exhaust, tuning disk brakes on front and rear, 1 steering + 2 throttle/brake servos, custom alloy servo tray and tray mounts, outerwears covers, rear wheelie bar, FG 2 speed with alloy pinion gears and alloy gear plate, alloy rear wishbone, fg alloy adjustable shocks, stock 26cc Zen motor.
HPI Baja SS:
23lbs 2.9oz (10kg 515g)
Full HPI Baja SS with SS exhaust, 1 steerings + 1 throttle/brake servo, turtle racing front and rear shock braces, front alloy shock support, modded gear cover and gear cover mount, modded rear brakes, outerwears covers, stock CY 26cc motor with modded engine cover.
Elcon Cleon:
22lbs 0.6oz (9kg 995g)
Full Elcon Cleon, no mods, 2 steerings + 1 throttle/brake servo, outerwears covers, stock Zen 26cc motor.
I will update again once I finish everything on all of the cars if anyone will be interested.
I probably left something minor out on one or more of the cars.
Thanks,
Alex
