DIY home anodising
Jasongtr
Oxfordshire, UK
Hopefully some would find this useful or inspiring to have a bash at this yourself
Before I start I take no responsibility for anything I’ve written, please do your own research before embarking on this, I am not a professional anodiser and you are dealing with potentially harmful chemicals do take the necessary precautions and use a big dose of common sense.
I started to think about doing this as I wanted a mostly black Baja 5b, I prefer to do things myself where possible too.
There are plenty of YouTube guides where they mostly use sulphuric battery acid for the main bath, it is hard to get hold of that now here in the UK, but you can get it off eBay from Germany, however you can anodise without it using a product that lowers PH levels in swimming pools, it’s called Sodium Bisulphate, the one I used was 92%
The other thing you need is Caustic Soda, this is nasty stuff so use carefully, a strong solution is used to strip the old anodising off and it works pretty fast, you will also need a 2% solution making up for a quick pre anodising dip (a few minutes)
The dye I used is a proper anodising dye, about £10 off eBay so I can’t see the point in using liquid clothes dye like some home setups use, I’m going black and that’s apparently the hardest colour to do.
The stages I do it are as follows, some guides I’ve seen use additional steps and whether that’s needed I couldn’t say but this is my way
  1. Caustic soda mix to strip old anodising then rinse with deionised water
  2. Industrial green degreaser solution with a toothbrush to get the part very clean, I wear nitrile gloves as the oil in your skin will leave marks, again rinse with deionised water
  3. A few minutes in the 2% caustic soda solution then rinse again
  4. Into the anodising sodium bisulphate bath, negative wire to the cathodes, I use 3x aluminium plates wired together around the edge and the anode positive wire to the part you want to anodise, this is suspended in the solution with titanium wire, you can use aluminium wire but I prefer titanium, the voltage and current depend on the size of the part, the length of time in this stage depends on how thick an anodised layer you want, google the 720 guide to work that out, rinse when you remove from this stage
  5. Next step is into the dye bath, I heat it to just under 60 degrees Celsius and hotter and it will seal before the dye soaked in, leave it for about 20 minutes, rinse
  6. Boil in deionised water for about 20 minutes to seal it
All done
I bought large plastic storage bins to put the cold solutions in and a couple of metal pots for the dye and boiling/sealing, my car battery charger was too intelligent to work as it expected a battery to be connected before it worked so I bought a 30v 10amp power supply for £50 off eBay
50212502135021450215502165021750218
All done
View attachment 50212View attachment 50213View attachment 50214View attachment 50215View attachment 50216View attachment 50217View attachment 50218
finally a anodizing guide on this forum! great post, bookmarked it. i think i WILL be trying this eventually.
Excellent , thanks for the share.
J
No problem, I’ll say now I’m doing a bit more today without the same success so far, not sure if the sodium bisulphate solution has weakened ( the alternative to the nasty sulphuric acid) but ill persevere today and report back, I have just ordered some acid though just to compare
Wow thats cool(y) keep usnup rodate on the results
ill post some more pics up later, ive ordered the acid but carried on for this lot with the sodium bisulphate, i think the 720 calculator works fine for the proper acid, as i followed that closely for one run and the part just went a lght grey instead of black, so ive continued with cranking more current into it, so for example if i was supposed to be using 0.3amps ive been using a full amp and thats getting the best results so far, it remains to be seen if the proper acid will indeed give a real jet black or in fact the dye im using just isnt that fantastic, bit it really will be ok for this project, its not like im trying to sell anything commercially, its just my own car
Continued with the sodium bisulphate as I don’t yet have the sulphuric acid and all the parts for my 5b that we’re purple or silver are now black, as suspected the amps need to be cranked up with the non acid anodising way, the rear chassis plate had 4 amps through it 50254
