Do not Disturb !!
considering i have not touched any needles like the high/low speed and idle this has been a good start, the left engine cut out at the end all i have to do is increase the idle and then both will run and idle good...the rubber pieces that dropped was between the chassis and pipe i will fit them back.
Im kicking myself in the arse for not buying the USA1 nitro before they discontinued them last year
i wasn't sure if the USA1 nitro was discontinued i'm sure Kyosho sold a lot off them..i like how they are both similar i guess a lot of parts can be swapped over. iv'e only seen a few advertised used locally and i got another one as well to restore...this one has the original shock/tank and exhaust coupler.
i like how it doesn't have independent suspension like a real redneck.
View attachment 110575View attachment 110576View attachment 110577
They are pretty much the same rigs from the mad force, to the mad crusher, then the USA1. The last two have 5 link suspension vs the mad force flat 2 link set up. Everything else, as far as I know, is the same.
The first two list Aus for the price. I assume that's Australia?
that's right but the sellers do ship international but either way it's massively over priced and without a engine.
it looks good but still a bit pricey...i wouldn't buy any online used rc from japan.
i didn't know that a electric mini mad force was made...the sellers price is impressive.
https://www.ebay.com.au/itm/3755356...Nr6IE90ux7nvX3qf7AybppRg==|tkp:Bk9SR8LfvNnzZg
I won't buy anything online that comes from another country outside the US, UK or Canada.
yep iv'e already bought enough here already i don't need anymore.
this truck had the pig tail exhaust that i didn't really like and now i got the body to fit with the replacement exhaust.
i bought a schumacher havok yesterday any one got one?
i saw a video of it running and the motor sounded good and i have to buy the 17mm wheel hex adapters for it as the fitted standard purple have a 3 teeth system that limits wheel choice.
foam cleaners are the best now i got to try a cream cutting compound to remove the white stain on the chassis.
