csdilligaf
I have a RR V4 and I just had a CY motor die on me and had a spare so I started to grind the case for clearance over the drive shaft. Noteing that the engine that came in the car had been rubbing the drive shaft I tried to take just a little more and ended up breaking thru the case. So now I am JB welding some stainless steel shim stock over the hole. I want a better motor anyway so if I buy a Zenaoh G290RC motor do the have the same problem with getting enough clearance? Why don't the make the drive shaft lower or have a better fix than cutting up your case? I looked on the MCD.com forum with no luck and have been trying for months to register so I can post but they don't ever let me sign up.
What is the best way to go?
thanks,
thanks,
