Does this look normal?
sperera
Australia, Melbourne
while repalcing the base gasket i notice this, does it look normal? Im refering to the gap between the teflong gasket and the billet inlet.
don't know how long its been like this but its never had an air leak before the base gasket went!
your carb bolts are too long by a couple millimeters. you ll want to put a nut on them, then cut off about 2 mm of the ends of the threaded area, then take the nut off to chase the threads clean, and re install. you may want to get a new Teflon gasket. as they can warp if bent and heated.
