Dog Bones
fastlane
Estherwood, La.
Will the fs dog bones fit the ramp? I am tiered of loosing pins and destroying cat5 retainers that stuff sucks. I read in a post that they fit. I just want to make sure. The reason for me getting fs is redcat is out ddm is out and mcd is way too expensive
I have used locktite, and JB Weld. Still they fly out. I read on rcu that the mcd boys are running those fs bones. I checked them out and for $34.00 for all 4 I will give them a try. I totally agree with you moo. No stock on new bones and mcd is just too high.
I understand about the GREEN LOCTITE but you can loctite these all you want they're wobbled out. At least 2 of them. I tried green loctite and jb cold weld
I already ordered the fs bones but in the mean time I will try to fix these for back ups. Thanks mooman. I wasn't trying to be hard headed I have read all threads on prerun two weeks before I purchased my TT. Had all needed supplies before I got it off of ups. even my kill switch.
You can't fix damaged dogbones with green loctite. It isn't meant to fill holes. The best way is to do it before you run them.
The FS dogbones should be the same size as the Redcats.
if it is that bad put a tack weld on it,lol, i'm sure it shouldn't fall out then. my dad and i used the brown retaining loctite, it's used for holding bearings and sleeves in heavy machinery and mine were too sloppy for the green but no problem for the brown to hold them in.
Oh wow that stuff is $31.99 a freakin bottle. It better work! Right?! I will first give fs bones a try sickboy said they have not failed yet on his friends mt. They're supposed to be more heavy duty that the ramps.
i'm still gonna have a machine make a d shaft one piece and for the diff cup they are gettin changed also, if all goes right the internal diff gears will be made one piece with shaft that have a hex so i can use same cups we use for center dogbones, hope then i can say by by to breakage.
I had a dog bone with hole hoged out a little bit so i drilled a hole in the end and put a set srew ,i was hard to drill ,ground flat spot to drill stiil going stong.
well my bones should be here before Thanks Giving Day. I intend on running the snot out of it after I enjoy the family. Maybe another vid this time instead of 30/30 I'll run 31/29
