https://m.aliexpress.com/s/item/32735195690.html 30.5cc/29cc top end, $28.00 /each
- 4 bolt, includes piston, ring, wrist pin, clips, wrist pin bearing, gaskets, bolts, spark plug
pull start w metal cog, $8.00 /each
carburetor $14.00 / each
baja cage handle 66158, $4.00/each
The cylinder head you bought from Ali Exp... is 2 bolt. You should have bought the 4 bolt. I bought two top ends at 28 each 4 bolt; cylinder head, piston, pin, wrist pin bearing, gasket etc, you know exactly like yours but the 4 hole design. Already used one of the kits and fired right up on the second to third pull. Still breakin the engine, only a tank so far. The engine has no settled yet and can tell it still doing its thing. To my surprise it seems to have more compression.
Had this issue it would not turn on and only w choke, which tells me it is lean. Thr same deal on the top end, right away I can tell once this engine wakes up its going to be nice. Had to give it CCW on both low and high to keep it running with consistent powerband, else it would bug down once wot.
This new top end likes fuel
Its unfortunate you bought the wrong one, it happens, I got all kinds of parts that I have to find the time and sell on Ebay, things that I buy and then have no use or don't fit. Keep an eye on that top end, retorque as necessary and have spare gaskets jic.
Besides, the squish will destroy the spark plug if its too high like you say. Something don't add up. I have bought plenty of times. Its no ebay for sure but you will get your money back if you follow their policies. You should have known better of manually move the engine, checking for squish is a matter of using solder into the chamber and like I said the spark plug electrode will bend. So it seems you bite more than you can chew, and its the seller's fault now...
You can still get full refund if you mounted it and done deal which I have done. Yes, will take pictures and possibly videos as their ARE plenty of buyers who want the seller pay for their mistakes.
