Drilling bodies
Put some thick grease on the body mounts. Set the body on gently. This will mark the holes to cut.
To cut my holes, I usually drill a small hole and use a stepped bit or a rc prop reamer to bore it to desired size. You can slowly use a hobby knife to 'drill' a small hole for the pilot too.
If you use just regular drill bits, go slow and use 2-3 bits, increasing in size each time.
