drive cup sleeves
Sscole2282
I'm looking to make some drive cup sleeves for my xt. I was wondering what id and od size tubing you are using and what material is working the best?
I'm using stainless steel that I found at a boat supply place. It is sold as replacement railing. It's a metric ID not sure off the top of my head but take some calipers with you and your cup.
heres a shot of Cu 3/4 " pipe on diff cups , lasted a year so far, no fractured cups since, carbon fiber tube is good option as well.
diff cup
hello, can you tell me if you used anything to secure the copper to the cup? if so what can be used.
no adhesion used, the fit is self retentive. dimple a spot past cup to shaft transition if doubtful. usually cutter leaves small lip that is ample.
I'm going to bump this thread instead of making a new one.
Anyone know if i can use the MT cups on the chimera? They are hardened and not squared off like the stock chimera cups.
I would bet those cups + copper pipe would be a solid upgrade
