MrFnisse
Hi there guys was out on a pretty rough bashing session yesterday. Went pretty well untill the cylinder head came loose. After a re-tightening of the 2 cylinder bolts it went fine again (except a higher idle ?!). When we were about to end the session for the day i did a rollover in pretty high speed and when i turned it back on the wheels there were no drive to the wheels when i applied throttle. First i though that the diff went to hell but after a little closer look i saw that one of the differential axles were missing. Found it near the car and had a look at it, and one side of it had broken off. The axle was pretty worn down and old so i did expect it was gonna happen. The driveshaft also came loose and i gave it a look and noticed it were somewhat bent, i changed them just before the run so they were completely new. The old ones were extremely bent.
Anyone knows if this is normal behavior and if there is any strengthened shafts / diff axles. One thought i had was that it might be the wishbones travels to far down when it has airtime etc and the axles get bent against the wheel/diff axles if you get what i mean :S kinda hard to put in words.
Cheers !
Cheers !
