Driveshaft Boits
Craig J
New Member
I ran my 5B SS for the first time since building today. I have noticed that the boots will not stay on over the ridges in the driveshafts. When the suspension is fully extended there seems to be alot of side to side movement between the transmission and drive hubs,??????
the boots slipping is a common thing with the baja fella,
but also yer better off getting some limiting cables so it never goes full droop,
swingy p limiting cables work great and are cheap, also cables and straps from other makers as well,
be prepared to change the boots regular as well, they tend to get torn quite easy on a baja, especially the outer ones,
its just how they are (y)
