jmrosko
I have Oneil Brothers 27.2 motor ported and maching and I'm going to be prchasing a side Dom. Can the stock drive train hold up to the power of this motor, pipe combo?
NO. they are steal and absolutly the tits. there is also going to be some kind of special when they first come out. if you plan on going all steel gears, don't buy the upgraded alum gear plate yet. you will need the one that is compatable with the steel gearsjigawatt said:now... i just read over a previous post, are the new gears really going to be aluminum? no thanks! they better be steel!
all i know is rob said he was going to talk to darrin sometime next week about the price. we'll have them before ya know it. are you all out of gears?jigawatt said:as long as that part comes out soon, then cool beans man.
any eta on these gears and other parts?
its a little late now, but are you venting the gear case.. i am also dumbed up by wich is better, mcd or redcat gears. i would think the mcd's, but i have melted both in speratic times. sometimes the oem gears would last and soemtimes the mcd's would last. then sometimes i couldnt keep anything in there.. my best resoults was with no gear cover or a well vented gear cover. with that i have not melted any gearsjigawatt said:first run of the weekend, no more than 10 mins on new mcd gears... melted! none left.
I thought I was the only person on this earth that said cool beans. Every time I say it people look at me all cockeyed. Good to know I'm not alonejigawatt said:as long as that part comes out soon, then cool beans man.
i thought the same thing. i ran with a sealed cover pretty hard for a tank(all steel gears) and the only thing that got a little more then warm was the clutch plate. the gears mesh is so perfect that they don't even get warm. my truck even roles better.hamster huey said:. So keep in mind without cooling to the gears even all 4 steel gears will get super hot they just wont melt. .
wow.. that sounds like a hole lota work. many of us run with no cover with no problems. wouldnt sugjest it at the beach, but the gears spin way to fast to get chewed up with off-road dirt running. just drill some pilate holes on the top of the cover. also, didnt you melt those gears in 3 feet of grass?jigawatt said:I'd have to put a screen on the inside of the gear cover after venting to keep things out... otherwise w/o the screen, I'd just chew up more gears before melting them. I have also been debating on rigging up a graphics card cooling fan for it, or a northbridge cooling fan, whatever would be small enough to get air circulation in there. Anyone know the voltage comin off the coil? If I can, I'll just throw in a 12v regulator and make a AC to DC and run the fan that way if it can fit![]()
that was one run, the other run where they melted is on a baseball field.kryptonite said:wow.. that sounds like a hole lota work. many of us run with no cover with no problems. wouldnt sugjest it at the beach, but the gears spin way to fast to get chewed up with off-road dirt running. just drill some pilate holes on the top of the cover. also, didnt you melt those gears in 3 feet of grass?
