brio
I just want to confirm with you guys what else is needed in order to install the DT1 Large air filter:
http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.8283/.f
I searched and saw that a V-stack is needed like this one:
http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.4363/.f
and possilby longer carb bolts, can someone confirm if the longer bolts are needed or the stock bolts will do? Anyone else running this filter? post a pic if you can? thanks.
Or should I just do the linkage flip and run the HPI baja filter?
